bgm stator & af lightened flywheel
db67
hi, just acquired a bgm stator & was wondering if it would be ok to run with an af lightened flywheel ? the reason for asking this is because i've read on a couple of forums that there is an issue with the pick up box being to close & rubbing on the inside of the flywheel, thanks for any info. db 67 ;)
smiffy1968
Main scooter: Nevermind Mk1 T5
You have read correctly. There are a few threads on here about it. I think with a bit of tinkering you can get it to work, if you look up the old threads all will be explained.
Good Luck.
