Cylinder pump rear Discbrake 2in1
morris-lambretta
Cylinder pump rear Discbrake lambretta 2in1system for testing on my scoot.
have a big lot Lambretta in bkk...... belive me !!!!!
FB: http://www.facebook.com/editprofile.php ... 1673051830
Have you got a bit more info on this Morris.
he has some pics on his face book ,i think it is W I P so i will say no more
morris-lambretta
This project start from my rear seal brake damange and I will done follow up form my racer scoot.
morris-lambretta
after will make a disc and keep position of calipper brake finish
stage 2rd will start the arm link again
morris-lambretta
again for stage 2 i wold like the hold on the arm and set lever for calipper to knockdown for service ,hidden the bearing on it lock by nut and ring
morris-lambretta
More difficult on this project how to make a cylinder pump ?on my scooter ,after we look my rear padel brake and think think think
then I have the answer to easy install on my frame
Will done like a pic and mach to the drum brake original 2 in1 like on my clip .
morris-lambretta
tube of flueid brake
morris-lambretta
morris-lambretta
A shape on my arm perfect and good work position ,the cyl good work the 3 rd stage finish but my job
not finish now I will done a flueid cable hidden inner tube frame ane test run again ...in soon
Thanks
    Users browsing this forum: Semrush [Bot] and 55 guests
