fixing kit info
carlos fandango
eden wrote:Does anyone know the full list of fasteners needed for a S2/eibar winter full body rebuild? :?: :?: :?: :?:
Ive got one for a S3 somewhere if thats any good ?
As I say, I'm ahead of you Eden :D
I've been trying to find out via the forums and even pm'd someone who say they sell fixings, but no reply :-? Anyhow, what I did find out is that the best person to contact is Buzz, he knows all the little anomalies with the fixings on Winters and supplies them too ;-)
DaveTomo
Main scooter: SX 200
[Don't know if this helps its for a series 3 though
Lambretta chain case side + front dampers 6mm
Lambretta chain case side exhaust 8mm
Lambretta cowlings 5mm
Lambretta cylinder head 8mm
Lambretta engine bolt shocker 16mm
Lambretta floor end caps 4mm, plastics 5mm
Lambretta fork link bolts 12mm x 1.5mm pitch
Lambretta front hub spindle 12mm x 1.5mm pitch
Lambretta gear linkages 6mm
Lambretta horncover/front mud/bridge 5mm
Lambretta kick-start lever 8mm
Lambretta rear hub (large hex) 16mm
LAMBRETTA HEADSET
Speedo Plate
3x M3x12mm Pan Head
Lambretta Headlight Rim
4x SX M3 x 25mm Raised Countersunk (For GP use 2)
2x Li M4x16mm Pan head
Light Switch
2x M3x25mm Raised Counter Sunk
Pulley Bush fixing plate
4x M4x10mm Bolts for pulley shaft holder.
4x M4 Washer
Lambretta Head Set Top
2x M5x40mm Raised Counter sunk
Light switch housing
2x M6x12mm Raised Counter Sunk
LAMBRETTA FRAME
Lambretta Rear Mudguard
2x M5x16mm Bolts
1x M5x16mm Raised Countersunk
3x M5 Flat Washers
3x M5 Nuts Nylock
Lambretta Air Scoop
2x M6x25mm Allen
2x M6 Washers
Lambretta Air Filter Box
1x M6x16mm Bolt
Lambretta Horncover
4x M5x20mm Raised Counter Sunk
4x M5 Cup Washers
2x M4x15mm Bolts
2x M4x15mm Raised Counter Sunk
2x M6x20mm Allen Bolts
2x M6 Washers
2x M4 Washers
Lambretta Floor/Leg/Bridge Piece/Front Mud Screw Kit
2x M5x15mm Raised Countersunk
2x M5x20mm Raised Countersunk
4x M5x25mm Raised Countersunk
6x M4x10mm Raised Countersunk
6x M4x15mm Raised Countersunk
6x M4x25mm Raised Countersunk
16x M4 Nylock Nuts
20x M5 Nylock Nuts
16x M4 Washers
20x M5 Washers
Lambretta Centre Stand
2x M8x20mm Bolts
2x M8 Nuts
2x M8 Washers
Rear Dog Leg
2x M6x20mm Bolts
2x M6 Nut
2x M6 Washers
Lambretta Seat
6x M8 x 20mm Bolts
6x M8 Nuts
6x M8 Washers
WINTERMODEL150
Hi,howard chambers/scooter surgery/buzz solomoto all sell series 2 rebuild kits ,but winter models have raised head countersunk cross head screws in the following areas
Floorboard end caps
Bridge piece
Legshield beeding end caps
Right hand side brake lever housing
Rear frame grill
Horn casing
Horn grill
Front mudguard
Panel handles
hope this helps
Dean
I suppose you could work on the S3 kit and tweak it. The flooring kit will be different plus front mudguard, possibly horncasting, stand is S1, headset is pretty much S3, engine is S3, rear light studs are S2, number plate fixings, arbox & scoop s3, as is seat. Fork links etc. Are S3 as are hubs and the engine. Rear mudguard is 4 bolt fixing, dog leg is 2xM7, can't remember legshields to frame under horncasting, or horncasting to frame.
Some of these I can check from what I removed and zinc plated, so maybe thinking about it, between us, we can get a S2 Eibar list together 8-)
WINTERMODEL150
Hi,i did help tony at buzz some years ago with the odd ball fixings on the legshields etc but not sure if he's got a pack made up yet, give him a bell i'm sure he can help.
Dean
WINTERMODEL150 wrote:Hi,i did help tony at buzz some years ago with the odd ball fixings on the legshields etc but not sure if he's got a pack made up yet, give him a bell i'm sure he can help.
Dean
He does, it's £25, which I didn't think was too bad for what it included, like T-nuts and rubber washers, and taking into account all the searching to find, most of the other stuff should be fairly straight forward though.
WINTERMODEL150
Hi,give these guys a call A1 fasteners croma industrial supplies ltd ,unit 5/6 brookwood ind estate,eastleigh,so50 9e,02380 650601 or fax 023800650601 ,this is where i got mine from lovely!!!!!!!!!!! :D
Dean
carlos fandango
eden wrote: what does it include?
does the kits contain cross heads or slotted head?
Dean, those Raised Counter Sunk cross heads are proving hard to find :(
^^^^^^^ :shock: :shock: Anorak ALERT :shock: :shock: :lol: :lol:
Cross head ? dont get posidrive you need phillips head . :cry: youve got me at it now :frog: :frog:
http://www.titanbolts.co.uk/acatalog/Ph ... rewsw.html
