Metalic base coat woes ?
carlos fandango
Hi,
Ive sprayed a silver metalic base coat, then masked off areas with 3m fine line tape and then ordinary masking tape. Ive then sprayed a different colour base coat, and then removed the tape, with good results.
The problem is when i sprayed the first coat of lacquer you could see where the masking tape had been :cry: , ive tried panel wipe thinking it is glue residue, but its still the same :cry:
Any ideas why :?
Should i have applied one coat of lacquer before the second colour :?
Thanks
Russ
carlos fandango wrote:Should i have applied one coat of lacquer before the second colour :?
My guess is that it hadn't fully gone off before you put the masking tape on. Having said that though it isn't very resiliant any way. Putting a coat of clear on is a good idea anyway before adding extra colours as if you make a mistake, it's possible to remove the last coat down to the laquer (with care)
carlos fandango
eden wrote:Rus, its because you have far too much time on your hands :cry:
lol thats the up side of not having much work on !
WINTERMODEL150
Hi guys,i've used 3m fine line tape with low stick masking tape from wicks with good results but its better to put a coat of lacquer on first as mentioned.
Dean
billy was jps
what kind of base coat were you using and what make of tape were you using . how long did you leave it before you masked up and how long di you leave it before you demasked
billy
carlos fandango
Thanks for the replies
I used 1 part base coat, left over night, masked off the next day with 3m fine line tape and then normal masking tape and newspaper. i pulled the tape of 5 mins after spraying. The marks were left by both tapes which was only noticeable after the first coat of 2pac lacquer.
Ive resprayed then, and another problem has occurred :cry: When i sprayed the second coat of lacquer, some of the base coat has reacted :oops: only in a couple of areas :cry: I would of thought it would of reacted after the first coat, if it was going to :?
The first coat was left over night to dry before a denib with a mirka grey pad.
If the second coat was to thick would this make it react ?
