vespa px125 engine trouble
newboy
had the engine in bits as cush went now all back together the kickstart wont engage, its like its slipping. any ideas?
Cheers Jack
have you over tightend the clutch cable ? slacken it off to check then re adjust .
newboy
Cluitch has had brand new plates. Slackend it off re adjusted still no joy
Nik
Did you put the clutch woodruff key in? I think this gives similar symptoms if you forget.
newboy
woodruff is deffo in, could the layshaft not be in far enough by anychance?
goldeneye
kickstart gear been put in upside down?
slowtype
Main scooter: PX200
goldeneye wrote:kickstart gear been put in upside down?
Sounds like the kickstart gear is upside down or the brass plunger has slipped from the clutch cover and is pressing on the the clutch.
Younger brother did the exact same thing recently.
    Users browsing this forum: No registered users and 80 guests
