Test the clutch version II
morris-lambretta
Testing the Japaniese clutch vertion II original creator from BKk Thailand.
Morris
have a big lot Lambretta in bkk...... belive me !!!!!
FB: http://www.facebook.com/editprofile.php ... 1673051830
joespeed
Morris
morris,what are you testing?what is the difference between the mk1 and mk2 versions?
do you need a packer?
regards
joe
joespeed wrote:do you need a packer?
i would say yes judging by the studs
10 inch Terror
Xbox live gamer tag: No.
I can't see how that is testing the clutch unit? Can you explain please.
morris-lambretta
Dear all
Thanks for looking on my Vdo test
-Mk1 make from the original clutch bell on last year ago it have a ploblem with the touching on side chaincase and no center of make and spinnining of the sporket .
-Mk 2 we make the new clutch bell and develope the japaniese clutch put in it and checking for the dimention with the thickness and touch inside chaincase no touch we can used 1.5 mm gasket also that smoothly when we ride on the Rapido top end or TS 1 or RB in my owners
On this VDO I can start the engine before and then I remove the end of exhust and take off the chaincase for checking of the operation the clutch with the center and friction when we used it .
Cherers
Morris
http://www.facebook.com/?ref=home#!/pro ... 1673051830
