Approximate Cylinder Head Retorque Mileage
Bilko
Main scooter: LI150
After what sort of mileage should the cylinder head be retorqued, bearing in mind it's an alloy cylinder?
Bilko's Oily Blog
dapper
100-150 miles
squeakmillward
I would probably check @ 100 miles then 500 mile intervals if it plays on your mind :)
Bilko
Main scooter: LI150
I had 100 miles in my head, but like it was like forgetting to speal a simpel word I couldn't remember.
Thank you. ;)
Bilko's Oily Blog
dapper
It's a feckin niggle when you've taken off the runner boards, bridge piece, head cowl, rear shock etc. to find that they are still torqued up OK :x :shock: :frog:
Donnie
more of a reassurance :-)
the amount of eejits that cant be arsed then wonder why they've fecked up their top end is daft.
Donnie.
Donnie wrote:more of a reassurance :-)
QFT
dirtyhandslopez
What I've been doing lately is leaving everything off, headcowl, the lot. Bolt exhaust up tight at cylinder and to box(or sprung to chamber), start 'em up and keep an eye on them with a infra red heat gun thingy. Turn 'em of when they are getting good and warm, stick a blower on them to cool them off.
Do that about three times then re-torque and put it all back together. Down the road they go...
Have seen no blowby on any scoots since doing this. Although a re-torque after a year or so won't hurt
That's not going anywhere...
Bilko
Main scooter: LI150
100 miles exactly so I did a check and it took a little extra tweak with the torque wrench.
Thank you.
Bilko's Oily Blog
idc1967iow
Did mine muggy 186,glad i did :shock:
