Disc Brake for Vespa Sprint/Rally Forks & Smallframe
tSR-VN
This is a disc brake unit including the hub to fit "oldtimer" vespas such as the Sprint and Rally etc with 10 inch wheels. Cost is 339.99 GBP which is for the unit as pictured : radial twin piston caliper, swing arm, disc, pads, hub, etc. Standard speedo drive is interegrated into the unit so just connect up standard cable and it will function as normal.
To fit and enable the antidive you do need to weld the fork - theres a lug visible at the bottom of the top picture which needs to be welded onto the fork.
CNC parts machined out of 6061t billet.
Any more info feel free to give us a call uk 02032877386
MK 2 smallframe disc :
....more coming soon
