Indian Lambretta dive
- spannerman
- registered user
- Contact:
Just fixed my mates Indian GP200,took for a quick spin SCARY!
.Have too fight the handle bars, they have a mind of there own ,turning right it wants too dive too the right,would not ride this at any speed,never experienced this before ,think it might be the fork springs but never dealt with these.Any Ideas would be appreciated.
bent frame
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
Forks- bent?
Springs- broken/ weak?
links- bent/ worn bushes?
spring retaining bits (holds springs in fork tubes at top)- broken/ missing?
spring rods- bent/ broken?
wheel bearings- worn/ broken up
rear bub bearing- knackered?
layshaft/ end plate- loose?
wheel rims (front and rear) loose on hubs?
badly bent frame?
engine mounts worn/ collapsed?
auxillary dampers on front- mismatched/ knackered?
that should keep you going........
Chris
badly bent frame?
Chris
Scootering since 1968.
- spannerman
- registered user
- Contact:
ooh err !
hub bearings ok no play,spindle ok not bent, forks feel good and look ok at a glance,not sure about frame,no play in rear hub but slight movement in layshaft in/out,had engine apart to clean up crank after blown piston,everything looked solid,front dampers seem to work ok pumped them in /out about the same strength,front wheel rim run out is about 1mm ,need to check other things on your list. need to strip forks I suppose ,never done this ,do you know anywhere that explains how to do this?any help would be great doing this as a favour!!!!! :fb:
- spannerman
- registered user
- Contact:
Have checked everthing without too much strip down,right hand engine mount appears to be strained towards the top!
quite possibly the cause?
very possibly as if front and rear wheels are not in alignment both horizontally and along the length of scoot it will give the bent frame symptom that you describespannerman wrote:Have checked everthing without too much strip down,right hand engine mount appears to be strained towards the top!
- spannerman
- registered user
- Contact:
thanks for that Ricspeed, will have to change them to prove it though
- spannerman
- registered user
- Contact:
changed engine mounts ,slightly better now, changed rear hub it was totalled + oilseal leaking. everything right as rain now,has done 200 miles since and is happy with it
