Best 210 Exhaust?
Posted: Fri Jul 08, 2011 6:54 am
by dopeshots
I have just bought a Malossi 210 kit and need a good exhaust to go with the kit. I'm planning lots of motorway traveling on my way to rallies
The budget is not a problem.
1/ which exhaust will give me the best power?
2/ which exhaust will give me the best torque?
3/ Is RH or LH exit best as I'm not planning on a spare wheel?
cheers
Re: Best 210 Exhaust?
Posted: Fri Jul 08, 2011 4:45 pm
by philhnottm
Im running a Taffspeed at the moment but considering a RH JL which i have on my other Scoot which is a quality bit of kit.
Phil
Posted: Fri Jul 08, 2011 8:14 pm
by LI150
Cant vouch for other pipes but love my JL Rh
Posted: Fri Jul 08, 2011 10:03 pm
by ducksta
jl r/h on a harry barlow 221 spot on and so easy to take off
Posted: Fri Jul 08, 2011 10:08 pm
by H,POOL GADGE
malossi 210 high revving kit = high revving exhausts pm, taffspeed, sip, scootrs, scorpian = big carb and casings matched.
but malossi bolted on, motorway, touring, 24mm carb = sito +, jl + spare wheel
Posted: Sat Jul 09, 2011 10:19 am
by philhnottm
Had a problem with my 210 at Cleethorpes ,Its a 210 harry Barlow ported 30ml carb with Reed valve taffy pipe , Lost power in 4th and was only getting 40 miles for a full tank??
It was spitting fuel out the bottom of the carb any ideas????
Appears to have semi sorted it self after a slow crawl back at 35MPH from the national.
Posted: Sat Jul 09, 2011 4:44 pm
by H,POOL GADGE
Mmmmm! I'd be stripping n checking reeds, carb and rings, probs reeds or carb....
Posted: Mon Jul 11, 2011 10:07 am
by ssteam177
ive just changed from a vintage 226 hotwing to a jl rz mark1 on my 210 setup the build quality on the jl is not as good as the hotwing (Oringed joints etc) but the the performace seems to have slightly improved with the jl. my setup with the hotwing was dyno'd @22.5hp
Posted: Mon Jul 11, 2011 9:13 pm
by philhnottm
H,POOL GADGE wrote:Mmmmm! I'd be stripping n checking reeds, carb and rings, probs reeds or carb....
Carb got stripped down tonight.
carb was fitted with wrong floats and loc -tighted in on the float bar hence the flodding and heavy fuel consumption.
should be sorted just shows buying scoots of e bay dealers can be a nightmare.
Been told teh Taffy pipe i have is spot on and a jl wont give me that much more .
