LD150 MK3
omalley
Main scooter: lambretta sx200
Hi
Any help would be appreciated about to remove engine from a LD150 mk3 but read all kinds of stuff about torsion bar removal damaging bearings etc.
What is the best way to remove engine / torsion bar do you need the special tool?
Thanks
David
ArmandTanzarian
Bofs
Not having removed an LD engine before I was expecting bone-breaking torsion bars flinging me around the workshop but they aren`t under that much tension at all.
After a bit of research I discovered this technique on LCGB I think to load the torsion bar enough to remove the pin. It was really easy in the end. Hope these pics help. Used a ratchet strap and a block of wood. Pin came out easily and no busted bearings.
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
omalley
Thanks thats great advice and the picture really helps.
David
omalley
progressing with strip down relatively well - although it has been stood for 45 years.
removed forks and now struggling to remove top race and steering lock / cable guide underneath.
should these just knock out? have tried as much force as i dare without being sure
thanks
WINTERMODEL150
Hi,undo the nut that holds the steering lock onto the top handlebar clamp and then pull the lock out.
The top handlebar clamp is a tight fit and will need the bars twisting from side to side to get it off,
Undo the m6 grubscrew that holds the top bearing retainer in ,then put a long drift up from the bottom of the forks and knock out the retainer (it will be tight ).
Dean
