Dies when hot
Posted: Thu Jun 09, 2011 5:03 am
Playing with an LI150 S3 with a 175 iron kit still running points @19 degrees and a 20ml carb.
Starts great from cold and runs through the air-box.
Going to be trying to sort it out latter today.
What I get is its runs great until it warms up at that point it just dies and is hard to start.
If you flutter the throttle and are lucky you can keep her running and limp back, however if you open the throttle
it just sounds like its been switched off. Baaaaaaaaaaaaaa sort of noise.
Normally when the engine is under load like going up a hill.
Now I'm going to be checking the timing and check the stator look for air leaks.
Any of you wise men have any other ideas I should look into?
Thanks.
Thanks.
