Dies when hot
RBG
Playing with an LI150 S3 with a 175 iron kit still running points @19 degrees and a 20ml carb.
Starts great from cold and runs through the air-box.
Going to be trying to sort it out latter today.
What I get is its runs great until it warms up at that point it just dies and is hard to start.
If you flutter the throttle and are lucky you can keep her running and limp back, however if you open the throttle
it just sounds like its been switched off. Baaaaaaaaaaaaaa sort of noise.
Normally when the engine is under load like going up a hill.
Now I'm going to be checking the timing and check the stator look for air leaks.
Any of you wise men have any other ideas I should look into?
Thanks.
Wisemen :D have you checked your fuel flow it isnt suffering starvation is it ??
tonydevon
Main scooter: '71 GP125
ok Im a total newbie to scoots, no idea if Im talking tosh BUT...
whats the manifold from the barrel to the head made from??
this problem was common on my old brit iron with alloy manifold and polished carb etc, carb was heating up as the engine got warm, the fuel vapourising or changing structure, and it just leans out giving the same symptoms you describe, fitting some isolator spacers with gaskets etc nearly always solved it, obviously this isnt the problem if youve got a rubber manifold
tonydevon wrote:isolator spacers with gaskets
strangely these were never fitted though all bikes ive had did have them
storkfoot
RBG wrote: it just sounds like its been switched off. Baaaaaaaaaaaaaa sort of noise.
This sounds like you're seizing. Is the engine run in?
check your filler cap is venting the tank
goldeneye
fit a fast flow fuel tap.
Bilko
Main scooter: LI150
kink in the petrol pipe, restricting flow?
Bilko's Oily Blog
al-super3
My gess would be condensor braking down if its not fuel or carb related
Cheers Al
Scream at me until my ears bleed
rog60
Main scooter: Indian GP200
older SH dellorto carbs had a nasty habit of the atomiser unscrewing giving these symptoms. Engine will idle but flood when throttle opened...happened to me...hope this helps.
