Running under panel filter
sydduckett
Anyone running an under panel filter on a 30m vhsh delly. Cant seem to find one that will fit and dont want to do the usual of having to buy to find it it doesnt..... :(
sef
sydduckett
eden wrote:Have a look for a big enough rubber elbow so you can use any filter.
I dont know if the TMX and my current Airstiker are further from the panel than the VHSH but this hose works for both on mine
Ta eden, any suggestions on best place to get said elbows.. ;) :D I suppose you just need to measure the size of the belmouth and buy the corresponding elbow?
ta
Craig H
sydduckett
eden wrote:got mine a few years back from here
http://www.lambretta.net/shop/shopexd.asp?id=5364
but there must be something like it in the UK
Says not for ts and reed block set ups, i have an rb with reed valve so would this not work?
Ta
