Page 1 of 3
SIP tubeless rims with tyres fitted...
Posted: Wed May 25, 2011 1:39 pm
by corrado
.... for Lambrettas.
I'm selling them with tyres mounted for those who aren't sure about getting them fitted.
Rim £56, Schwalbe 3.50 x 10 Raceman or Weatherman £37, fitting £5, P&P £8. 1 = £106, 2 = £204, 3 = £300.
£3 per tyre more for Whitewall Weatheman.
Re: SIP tubeless rims with tyres fitted...
Posted: Thu May 26, 2011 10:29 am
by drunkmunkey6969
Are they the new 'Mk2' version....and do you do the matt black ones too?
Posted: Thu May 26, 2011 12:58 pm
by mark
Af do matt black not sip, I have both a silver sip which is pure quality with a deeper well thicker body area , longer studs and all the nuts and washers which racemans fit to easy and a matt black Af one which doesn't do any of the above
Posted: Thu May 26, 2011 1:37 pm
by soulsurfer
SIP do matt black and matt black with polished edge...
http://www.sip-scootershop.com/main/bas ... a=1&sort=0
[Edit] ...and so does Martin :D
by corrado
Yes Dan, they're as Mark says.
I have got them in Matt Black, Black with polished lip (mmmm) and Silver. I've not got the polished alloy ones at the minute.
Keep quiet about it as I am "JUST"Lambretta ...... but I've also got Veshpa ones too in Black with polished lip, Silver and polished alloy.
As a rule I don't like Whitewalls but the Black with polished lip and Whitewall Weathermans do look the dogs danglies.
Posted: Thu May 26, 2011 5:18 pm
by Doom Patrol
Is it wrong to lust after a wheel rim? :lol:
Posted: Thu Jun 02, 2011 12:54 am
by corrado
Weatherman Whitewalls on Matt Black rims....
Racemans on Silver rims ....
Racemans on Matt Black rims ....
Weathermans on Black rims with polished lip ....
Posted: Thu Jun 02, 2011 6:59 am
by soulsurfer
You're right about the white walls. Nice :-)
Posted: Thu Jun 02, 2011 8:50 am
by bristolmod
yes- they look very nice indeed.
Just to clarify. Simply remove old wheel and pop on new wheel? No fettling required at all?
Chris
Posted: Thu Jun 02, 2011 9:39 am
by mark
Take off wheel , remove old hub studs, fit new hub studs refit wheel
