kickstart
steve.earby
hi Sean
hope this finds you well having a little problem with kick start sometimes it feels like its slipping this often happens after a ride out once i stop it can sometimes take a while to kick off again feels like there is no compression, if i leave i a while it starts up about the time it takes to roll and smoke a fag thought it was overheating but dont think it is now any suggestions
cheers
steve
it sounds like the clutch maybe slipping a bit when warm...................
but first just try slackening the clutch cable a tad...............
steve.earby
clutch as slipped a few times will try that tomorrow and let you know how it goes cheers just my luck it starts playing up as i plan for Scarborough will you be going and is dan would like to say hi not had the chance yet was thinking of heading to wigan to check out you guys racing is it worth seeing
