classic rapido with 60mm crank & clubman charecteristics
mickdale
anyone got a dyno for a classic rapido 200 (or 225 if they do classic) with a 60mm crank and clubman?
can you get large block casa kits?
cheers
mick
TS1-200
Yes casa do a 210 kit for 200 casings. similar to the 185 kit but bigger.
Keep on keepin on
goldeneye
go rapido! cheaper, re-bore-able, pulls well. the classic 225, 28 or 30mm dellorto, and 42 clubman is an ideal rally set up, pulling GP20019x46 . will easily pull 20 tooth front . if i had a small block lammy, (i was after a series 1 150 earlier this year) i would consider the CASA, but the reports of how good the Mugello 186 is, i would choose that over any small block kit. bite the bullet. although........... :D
