Mag Housing
Posted: Thu May 19, 2011 8:49 pm
by #1GP200
Got an Li125 casing and mag housing. Fitting a GP crank and NU2205 bearing.
Can i use the original mag housing or do i need a GP housing ?
Cheers.
Re: Mag Housing
Posted: Thu May 19, 2011 8:55 pm
by Robi D
You should be just fine with the original. Only the ser. 1 mag housings are different.
Re: Mag Housing
Posted: Thu May 19, 2011 10:43 pm
by #1GP200
Cheers Robi was hoping that was the case.
Re: Mag Housing
Posted: Fri May 20, 2011 9:40 pm
by TS1-200
Don`t forget to leave out the spacer in the bearing housing, as the GP mag bearing is wider than the SX/LI one.
