Having problems with fitting flywheel, its a new Indian electronic kit, it seemed to be rubbing
when tightened up.
It looks like the inner of the flywheel is rubbing on the stator bolts, any one else had this problem
I thought you could take off the inner housing (which would be easier to file) by unscrewing the screws round the edge, after loosening 2 of these I noticed that these where actually holding on the flywheel magnets
Anyhoo, the 2 screws that I loosened now won't tighten back up, is this now unrepairable
They still seem to be held in well.
If its still OK to use, is it a question of filing round the bottom edge until it doesnt rub any more
If you look at the pictures I have an edge sticking up after the magnets, this is what must be rubbing....
regards
Piatti
