Deceleration issue
Lam-d
Main scooter: 71 Gp200e
Lads just a quick question .... setup Mb stg4 200 on a phbl 25 60 choke 50 idle 102 main aq266 and a d29 needle second clip from top airscrew 1 1/2 turns out with Kba exhaust ... problem when i am decelerating after the bike has warmed up it "hangs" for a bit before dropping and then the idle sits high i have tried adjusting both the idle and air mix .. is their something i am missing or not doing or needs changed ....Ta Bill
Special X
Try a 52 or 53 idle jet, sounds like it's too weak at idle.
Lam-d
Cheers bud thanks for the advice .....
Danger
Main scooter: lambretta TV200
sorry billy m8 for butting in , jason it has a new 40 slide in it everything is new in that carb ,lol got it from me
Diablo
Check the float valve. Quite often its a 200. Change this to a 300 or 350 if so. Also check your float weight.
Danger
dan already been done, the carb was mine an was working fine on my scoot
