Deceleration issue
Lads just a quick question .... setup Mb stg4 200 on a phbl 25 60 choke 50 idle 102 main aq266 and a d29 needle second clip from top airscrew 1 1/2 turns out with Kba exhaust ... problem when i am decelerating after the bike has warmed up it "hangs" for a bit before dropping and then the idle sits high i have tried adjusting both the idle and air mix .. is their something i am missing or not doing or needs changed ....Ta Bill
Cheers bud thanks for the advice .....
- jason frost
- Dealer
Slide to weak
Check the float valve. Quite often its a 200. Change this to a 300 or 350 if so. Also check your float weight.
