t5 front roller bearing
Posted: Sat May 14, 2011 9:39 pm
by rio
Hi All Im going to change a worn roller bearing from the front wheel any advice how to get it out , my plan was to heat up the housing turn it over and give it a smack hoping the bearing would drop out is this the best way?
Re: t5 front roller bearing
Posted: Sun May 15, 2011 3:33 pm
by gadgetman
Should just tap out but make sure you use some sort of correct diameter drift so that you tap it out squarely though. Why are you just changing the needle bearing ?
Posted: Sun May 15, 2011 6:49 pm
by rio
I have previosly changed the large bearing under the circlip but at the mot I was told I still had play when the tester rocked the front wheel so I thought it must be wear in the roller bearing
Posted: Mon May 16, 2011 7:29 pm
by rio
Hi took your advice and tapped it out no problem (no need for heat) tapped in the new one ressembled and wheel spins as sweet as a nut with no play when rocking the wheel, result. Whizzed up the road as a test and no probs good brakes and a working speedo. ! :)
