The largest carb I can use
jaymarriott
Main scooter: 1961 TV2
Evening all,
What is the largest carb you go on an Imola and what pipe?
I'm have a 28mm dellorto and a 30mm BGM PWK carb waiting, I've got 15/46, 5 plate clutch and going for a Ron Moss clubman, if I can find one.......
Oh yeah, I'm 18 stone :oops:
Cheers.
Diablo
The question should always be what is the smallest carb I can get away with. of the 2 I'd go for the 28mm delly
jaymarriott
Very true :)
I want to try and get the best I can out of it, I was told a 34mm Dellorto.... mmmm
Diablo
I think you'll get more useable power from a 28mm rather than a 34mm.
soullad
ran a 28mm delly on an Imola, it pulled 16 x 46 (Clubman).. both scoot and me run a series 2 frame.
jaymarriott
What chain can you use with a 16/46? Can you get a 80 or a 81 Iwis modded to fit?
81 link with a lth downwards chain adjuster
jaymarriott
I've been trying to find one of those Varichain things, anyone got one to sell?
