Ballpark jetting for a 25mm Dellorto
Posted: Sat May 07, 2011 8:36 pm
by LI150
Anyone got any ballpark settings for a Standard 200 running a AF clubman please..
Re: Ballpark jetting for a 25mm Dellorto
Posted: Thu May 12, 2011 7:43 pm
by LI150
Anyone ??
Posted: Thu May 12, 2011 8:12 pm
by Killkenny
open bellmouth of filtered? Air box? remote? need more info fella.
Posted: Thu May 12, 2011 8:20 pm
by LI150
Running through an airbox.
Posted: Thu May 12, 2011 8:34 pm
by Killkenny
well this is what Id use on a 25 Phbl (presuming the airbox has been drilled to let more air in) on a standard with clubman for a good starting point
98-100 main
48 idle
Dq 262 atomiser
D22 second clip from top
air mix screw 1+ half turns out
40 slide
2.5 needle valve
should get you something like near
Posted: Thu May 12, 2011 8:37 pm
by LI150
Thank you
