filter help
sydduckett
Anyone give me suggestions for what filters will fit on a 30m Delly VHSH?
Thanks
sef
Thru panel or under panel ??
you can use Ram Air type or Marchald types most dealers sell or go direct on the Ram air a tad cheaper .
sydduckett
Toddy wrote:Thru panel or under panel ??
Needs to go under panel but have a little more clearance as the panel has been vented. I have seen a small flat one but cant remeber where.... :evil: Also need to know the correct size as the VHSH as the mouth is approx 63mm across.
Ta
