mikuni 24 manifold
DaveTomo
Main scooter: SX 200
What is anybody using for a mikuni 24 tm manifold on a rapido 200 barrel? I've got a 25mm Manifold PHBL I've put on but to me it seems the carb sits to close to the engine mount,has anyone tried one of these http://lambrettaspares.com/spareparts/2 ... 0050k.html and if so what rubber do you use? I must admit I thought the 25mm delly manifold was the one to use (this is the one I've got at the moment http://lambretta.co.uk/catalog/product_ ... ts_id=3054 using the rubber mount that came with it) any help would be gratefully appreciated
I supply (and use one myself on a Mugello 225) the MB manifold and I've had no clearance issues with it. MB do a rubber to suit but I use the radiator type rubber as I can cut it to size to clear the petrol tap arm.
DaveTomo
PM sent
