oil on t5 classic
Tosh
finished rebuild,now i`ve filled oil tank an fuel tank after being totally drained,will i have to mix some 2stroke with the gallon of petrol i`ve got in the tank to give it enough time for the oil to prime itself,i know i might sound thick but not done this before :?:
timexit17
Main scooter: GP 225 Extra S type
yes.
2% mix for the 1st tank, it might smoke a little when it starts also mixing the autolube eventually but it's better than having no small end lubrication until that point!
timexit17 wrote:yes.
I'd agree with that, my T5 Classic had the oil feed disconnected so I used to pre-mix at 2%. Pulled into the local Asda almost empty, tipped in the required amount of oil (Asda 2 stroke) and then realised that it weas card only and I didn't have my card with me :oops: It started up ok and managed the 3 miles or so to the next garage with no problem other than a lot more smoke than usual :wtf: .....I reckon it would have run on 100% oil ;)
Tosh
thanks chaps for the replys going to sort it tonight might keep garage door open wider than nomal when the auto lube kicks in.
Paul
