Cause of 4 stroking?
djh66
Main scooter: 150 special
My 185cc with 24mm PWK, breathing direct, seems to be 4 stroking between 1/4 and 1/2 throttle, I'm running a 34 pilot and a JJH needle on 2nd clip from top, any ideas?
Cheers Dave
Bring Me Sunshine COYH
djh66 wrote:My 185cc with 24mm PWK, breathing direct, seems to be 4 stroking between 1/4 and 1/2 throttle, I'm running a 34 pilot and a JJH needle on 2nd clip from top, any ideas?
Cheers Dave
JJH is a bit rich, assuming you have tried lowering the needle (raising the clip) you could try a GJH, that's a bit leaner in the mid range.
djh66
I'll try it tommorrow, with the needle clip on top, if that improves it, i'll look to purchase a GJH.
Thanks
djh66
Has certainly stopped the '4 stroking', only thing now, is the revs take a while to drop when easing off the throttle?
Are ther any UK suppliers of PWK/Kehein needles?
Dave
joeswoonara
Main scooter: jet ts1
C*NTSPEED
Yeah allens
GEMINI S.C.
BLACK WIDDA'S S.C.
djh66
Cheers chaps, advice appreciated as always
Dave
