NK / ADS end can support ?
carlos fandango
Anyone else having trouble with the bracket not clearing s3 panels?
Ive just ha an NK and no matter what i do it fouls the panel on the kickstart cut out! Not when on the stand but it would hit the panel when at about half suspension travel ??
Any one got one and its ok?
red ghost
Main scooter: lambretta gp150
I understand your problem, but can you post a photo, maybe somone will see something you don't.
arthur
is it the end can or have you the nut and bolt in the wrong way round like i had? :oops:
carlos fandango
red ghost wrote:I understand your problem, but can you post a photo, maybe somone will see something you don't.
I cant post a pic untill monday now, as the scoots at work.
The bracket has three fixing points to the chain case (the three studs to the left of the drain plug) with 29mm long tube spacers.
The panel hits the part of the bracket furthest away from the drain plug.
I like to fit the pipes and then take the shocker off, and lower the scoot onto the bump stop, to mimic full suspension travel.
Ive tried fitting smaller spacers (20mm) and it still hits :evil:
I spoke to AF and they said they were aware of the problem :? and are redesigning a bracket :? :evil: :evil: :evil:
So it was out with the hacksaw, and its now a two point fixing :baddevil: and ive made another bracket to fit to two studs by the shocker mount :D so its
now a four point fixing :D :D .................. only took 4 hours of f@@kin about :twisted: :twisted:
arthur
l told Ben its the worst fitting exhaust i've had like you i've cut my back spacers down ... :twisted:
carlos fandango
arthur wrote:is it the end can or have you the nut and bolt in the wrong way round like i had? :oops:
No its the part where the long bolt and spacers go.
And i took a pick of the bracket when it arrived before i took it apart for spraying ;) :)
But the end can is unusually close to the panel :? make turning the panel handle difficult :roll:
carlos fandango wrote: I spoke to AF and they said they were aware of the problem :?
Are you sure you don't mean:
carlos fandango wrote: I spoke to AF and they said it's the first they've heard of it. It must be the way I've fitted it
:shock:
Eibar
Main scooter: Eibar TS1 1966
Our NK pipe fouls in exactly the same place.
potato
carlos fandango
Just thought id post some pics of what i had to do ! it might help someone else
First is the part that hits the panel
The second two are the bracket i made. it would probably be ok with just the two mounting points but ive always had problems with the JL system.
Wayne Miller
carlos fandango wrote:Image
Thats a good design mate but f@@k me what have you done to it? It looks like its been ran over by a bull :-) :-) :-)
Stay tuned..............
