GP handlebar control rod slop.
Ihateyoubutler
Does anyone know an easy way to get rid of the slop in the handlebar control rods? Does anyone make the plastic bits in the outside end of the handlebars in alloy or metal? Anyone converted the older type splined rods? (which I have).
Thanks.
have come across a few of the splined type of rod welded to the tube
i,ve always prefered to weld rods into bars..................its the ONLY way to eliminate that slop..........and to ensure that it never occurs............again.
italian splinned rods and brass pulleys are best of course............
with indian set up............the pin through the plastic pulley will still be a prob......sooner or later............
would araldite work . i wonder?
i suppose you could try that mark................... :shock:
and maybe let us know after 5000 miles............................. :lol:
i will in a couple of weeks if i remember lol
:lol:
you must do some serious milage matey.................... :D
i mean i will glue it in in a few weeks lol
;) :lol:
red ghost
Main scooter: lambretta gp150
I bought this one and the throttle one
http://scootrs.com/moreinfo.cfm?Product_ID=25
and made some new stainless control rods, drilled the rods to suit the scootrs parts and thru bolted them, no play at that end. As for the other end,I remade the plastic parts in stainless and fitted roll pins.
A plan for the future is to loose the roll pins and tap threads into the stainless parts and fit the right lenght grub screws.
8-)
    Users browsing this forum: Google [Bot] and 17 guests
