gear cables?? sorry for being thick
oggy
does the gear arm on the engine go forward when first is selected and back for 2,3,4 gears as can only select 2 at mo,thanks
lammiki
Main scooter: lambretta S2
cables go back to front front to back thats to say front cable at headset goes to rear on selecter therefore rear of selector goes forward for first front of selector goes back for second third and forth hope that makes sence pro not derrrr
oggy
i dont have a normal handle bar selecter,its on a chopper type,but thanks,i will know if i can find out the answer to my question
oggy wrote:does the gear arm on the engine go forward when first is selected and back for 2,3,4 gears as can only select 2 at mo,thanks
yes
oggy
thanks,iv nearly finished the scoot,so no more probs i hope!!!!!!!!!!
oggy wrote:i dont have a normal handle bar selecter,its on a chopper type,but thanks,i will know if i can find out the answer to my question
it will be the same
