Stator Plate Question
Posted: Thu Mar 31, 2011 10:27 pm
Harry Barlow recommends aligning the timing mark on the P2E casing to the 'I.T.' timing mark on the stator plate when setting up one of his Stage 4 tunes on a P200E motor.
Problem is the stator I have got is an early (genuine Piaggio) Ducati stator plate and it only has a simple mark cast into it which aligns with the timing mark on the casing.
Is it a case of simply moving the early stator plate I have got in a clockwise direction by the distance between the marks off a later stator plate?
