Stator Plate Question
steeleyscoot
Harry Barlow recommends aligning the timing mark on the P2E casing to the 'I.T.' timing mark on the stator plate when setting up one of his Stage 4 tunes on a P200E motor.
Problem is the stator I have got is an early (genuine Piaggio) Ducati stator plate and it only has a simple mark cast into it which aligns with the timing mark on the casing.
Is it a case of simply moving the early stator plate I have got in a clockwise direction by the distance between the marks off a later stator plate?
gaz_powell
http://www.scooterhelp.com/tuning/vespa ... stall.html
this shows you how to do it with the early p200 stator using a gauge and strobe
however i have in the past done as you say by retarding the stator - turning clockwise the distance between the two marks with no issues
steeleyscoot
Cheers mate, much appreciated.
