poor quality fuel ?
gaz_powell
what symtoms have people had that they can put down to bad fuel ?
Reason i ask is that i`m stumpped at the minute.
P200 was running fine but due for a rebore - decised to get Harry Barlow to tune a top end. put it all together -only other difference was a SIP fast flow fuel tap. Went out to start running in and did 30miles with no issues went on reserve so filled up at the nearest garage which was a supermarket and went home (about 0.5mile). Went back to it the weekend after to do some more miles. It was a t*£t to start, wouldnt tick over, would only run with choke - so i started the usual things - cleaned carb, new plug/lead/cap,new cdi, new stator no difference - started to have a suspicion the clutch side seal had gone so drained the g/box -all seemed okay. Thought stuff it ripped engine out and stripped it - there was nothing wrong the seal so i rebuilt it with all new seals and bearings - fired it up no difference.
went back in garage tonight and done a bit more - agin a pig to start ,cleaned carb, drained g/box oil to check again, blocked the clutch breather up again no difference - however it will now tick over but it is still not as crisp and responsive as would expect and just doesn`t feel/sound right and it occasionally backfires through the carb if the filter is removed
will drain the fuel tomorrow and try some new from a known brand
any thoughts ?
goldeneye
any joy?
H,POOL GADGE
is it tippo's scoot ye sorting gadge?
goldeneye
its gaz"s mk 1 and a half.
gaz_powell
no mate its mine
havent seen tippo for a few weeks - his bike was running fine when it left me althought it was a bit slow when i went out on it
H,POOL GADGE
ye went to knaresboro-york with him and chip pan, strugled to get 55-60mph and drinking petrol, but on the way back. told him to get head down(laughed at him all the home) but 65-68mph pipes doing now,t for him, think he,s gonna see ye about sorting an harry barlow tune....
ps how,d ye get on with ye scoot
Diablo
Supermarkets have admits to using bio ethanol in their petrol but they should sign this to say so.
Ethanol like alchohol requires bigger jets and higher compression to work properly so who knows?
gaz_powell
cheers Al
pm sent
    Users browsing this forum: No registered users and 26 guests
