iffy cush drive symptoms
Posted: Wed Mar 30, 2011 1:44 pm
by C*NTSPEED
what sort of symtoms does an iffy cush drive produce?
Re: iffy cush drive symptoms
Posted: Wed Mar 30, 2011 2:20 pm
by sean brady scooters
apart from the rattly noise,it would usually lurch/jump into gear instead of selecting smoothly.
Posted: Wed Mar 30, 2011 4:08 pm
by C*NTSPEED
trying to single out a prob ive come across when i gear down it sort of makes the wrong kind o niose its hard to explain the last time i had this tho was on the 210 and i changed the clutch it it was all ok but this time ive changed to a fourplate clutch new springs steels the works and its stil there
the springs were pinasco and all same length the steels were flat as a pancake
Posted: Fri Apr 01, 2011 4:41 pm
by C*NTSPEED
sean brady scooters wrote:apart from the rattly noise,it would usually lurch/jump into gear instead of selecting smoothly.
it selects gears very smooth how ever its snatchy on take off and gearing down makes a whining sound if not done at very low speed is it the clutch or cush drive?
Posted: Sat Apr 02, 2011 6:06 pm
its defo the cush drive
Posted: Sat Apr 02, 2011 6:10 pm
by C*NTSPEED
sean brady scooters wrote:its defo the cush drive
i thank you
