Series 1/2 front mudguard fitment
MAB
Hi,
After a bit of advice and a photo if there is a chance.Which are the holes that you mount your mudguards LOWER tubuler mounts to,a friend of mines legshields have a couple of mounts already tacked to the legshiels but mine believed to be early series 2 do not so unsure where to fix to do i need to drill 2 fresh holes ? - any ideas would be appreciated .
Regards Mark
dont drill .....ill get a pic up
its the raised bit below the three hols for the runner strips at either side
MAB
Bit of a problem my legshields dont have those 2 raised areas, have you seen any that dont before ?
Mark
MAB wrote:Bit of a problem my legshields dont have those 2 raised areas, have you seen any that dont before ?
Mark
yes ...............spanish ones
MAB
Mmmmm these must be spanish then , any ideas where these bolt through sorry for so many questions set my self a bit of a deadline to get it ready for scarborough :shock:
Mark
bolts dont go through the leggies as these are just captive nuts efectively welded on to fix mudgard to
MAB
Legshields are now painted and with none of those captive nut/brackets not really sure where to fix to, head scratching time again i think.
Mark
well unless you want a bolt head between the runners inside the leggies ....you need to weld some on mate
what happend to the dry build????
