Need to re-blast?
PRE0ATS
Main scooter: Li Silver Special
I would really welcome some input/opinions from those of you know what you're doing when it comes to painting.
I bought a Series 2 in bits a short while ago (an unfinished project), which had been stored in the guys garage for over a year. Before it was stored, everything had been sand blasted and the frame/forks were powder coated and the bodywork was grey primered.
Some bits of body work seem to have been sparyed in red oxide before the primer (small bits of the red oxide not covered), but the side panels, legshields, and rear runners seem to have only been sprayed in grey primer and there appears to be small flecks of rust (?) now breaking through the primer (see photos below).
I assume that the bits not sprayed in red oxide, and now showing flecks of rusts, will need re-blasting (or acid dipping etc) before painting. Is this correct?
Thanks,
A
stafford
yes mate blast them and acid etch them, then carry on as normal from there
PRE0ATS
stafford wrote:yes mate blast them and acid etch them, then carry on as normal from there
Thanks for the quick confirmation - didn't want to waste money getting them re-blasted if it wasn't needed, but equally didn't want to get them painted only for the rust to come through.
Got knows why he only had some bits sprayed in red oxide and not all?!
dont forget to assemble all body work to check fit etc first ....any tweaks needed are better done now
