S.I.P Tubeless as a PX spare ?
Mongo
Main scooter: Vespa Rally 200
Does anyone know if you can fit the new S.I.P tubeless rims as a spare wheel under the left hand panel of a PX ? :?:
goldeneye
shouldnt see why not. but why bother? lot of money just sitting under a panel doing nowt. use one of the wheels youve taken off as a spare.
grimspeed
Main scooter: gp 283 kx
the off set on sip tubless rims are different to std ones so using a std one as a spare with tubless rims is a no no.
yes you can use one under the panel. no problem ! i have one on. best if you use some nylon washers behind to spare the alu from rubbing.
