LONG CHAIN?
roy242
Main scooter: GP muggy 186/GP RB20
hi all! could someone tell me if this chain is too long?
I guess I must be more stretched, with no belly. no?
I hope you can understand .. and I use the google translator ..
thanks!! ;)
J1MS
Looks a little too worn. Could do with being a little tighter, or a top down chain adjuster fitting.
roy242
would have to be so maybe? chain .. I think my engine is way too long or too worn ..
I have 46/16 transmision
I think my chain is as in the last picture ... no?
Image :?
46/16 uses a stretched 80 link chain but I doubt it would stretch that much. It looks like your chain is too long in the first place, maybe 81 link?
roy242
I will ask the mechanic .. thanks!
roy242
corrado wrote:You may need one of these ....
http://www.lambretta-teile.de/Chain-ten ... -Lambretta
THANKS!!! :bouncyeng:
roy242
I found this picture here which shows how it is now well placed ... .. I have a question ..
tense is used only upper chain? no need to place the bottom?
some say you should ...others say not ....best fit one really
i need one of them off you martin
