Changing a set of PX Forks
Posted: Mon Mar 14, 2011 6:59 pm
by philhnottm
How long should it take a dealer (mechanic) to replace a set of forks on a PX.
Ive heard from 4- 8 hours ??
makes a big difference at £40 Plus and hour
Thanks
Phil
Re: Changing a set of PX Forks
Posted: Mon Mar 14, 2011 9:37 pm
by rusty90
do it yer self...get a haynes manual and read it..it aint that bad,if you lay the bike down..
Posted: Mon Mar 14, 2011 9:40 pm
by timexit17
you can do a straight swap in less than an hour! 4-8 hours? wtf!
the YTS boy could do it in less than that and give them a respray in between!
ok: to swap them, attach mudguard, new bearings, swap hub, new cables attach everything and check for free play and tighten maybe 3 hours tops.
Posted: Wed Mar 16, 2011 1:56 pm
by rusty90
disc or drum forks shouldnt take more than 3 hours tops to remove and re fit..ring around your local dealers for a quote or better still see if some one on here will do them for you...anyway whats wrong with yours.??
Posted: Wed Mar 16, 2011 9:12 pm
by philhnottm
Have some new ones from Ron daly which have just come back from Quality Chrome in Hull .
They will be going on a disc model.
being so crap at mechanics (even basics) and most other DIY i use plumbers for plumbing builders for building work and mechanics for car and scooter work.Dont want to screw the scooter up hence want the expert on it.
Keeping mechanics in work for 20 years !!!!!!!!
Posted: Wed Mar 16, 2011 9:26 pm
by sean brady scooters
crikey matey , i feel your pain .and quite understand that if your not (as in this case )mechanically minded at all ..or even practically minded and good with your hands at all in anyway that you would of course cringe and begrudge paying others (mechanics,plumbers etc etc )to do all those minor jobs that others could and often do manage ...
i would really like to see you do this easy/straightforward job yourself ,in order to save yourself a small fortune and to boost your ego .. :D
Posted: Wed Mar 16, 2011 10:40 pm
by philhnottm
Sean
i want it ready for this season not next!!
Phil
Posted: Wed Mar 16, 2011 11:32 pm
lol,fair play matey ...hope you get it sorted quickly and quite cheeply :D
