Lambretta horns - can they be repaired??
skootaloon
Hi all,
I have a couple of old Lambretta horns that have stopped working. All that has happened to them is that they have been stored away for some time and now they don't work. What happens to the horns over a period of time which prevents them working?? Is there a cure or repair?? I know they are available to buy "new" but if the old ones can be revived then all the better.
Any help would be great.
Best regards
Simon Balistrari
daz.h
i drilled the rivets out of a old horn that had been used and stopped working to find the solder had cracked and the copper wire came away from the earth, easy fix.
