Hi All,
Basically, the idea behind this thread, is that we invite all forum members to post the settings they are currently using on thier scooters, in order to develop a database of information, that can be used by all visitors as a resource for learning and setting up thier own machines.
Please get involved and supply as much info as you can, you never know, you may need to use the resource yourself one day!!
NOTE: Please don't ask technical questions or start discusions about carb settings within this particular thread, please start a NEW thread if you need to have a discusion. This particular thread is for settings information only.
So just add a reply below with your carb set-up and watch the list grow!
Vespa Carb Set-ups.....
- drunkmunkey6969
- Moderator
- Contact:
- drunkmunkey6969
- Moderator
- Contact:
Scooter: PX200
Engine: standard P200 cylinder
Inlet: 180 degree inlet
Pipe: JL3
Gearing: Standard (no T5 4th)
Carb type: 26mm Spaco based VORTEX
Main Jet: 160 main
Idle jet: 100/50
Air Corrector: 120 AC
Mixer: BE4
Pinasco 215 cc
SCOOTER: P200E 1983
ENGINE: Pinasco 215 cc kit (no matching, just bolt-on)
HEAD: Pinasco
PIPE: Polini 200cc exhaust
CARB: Spaco 26/26 190/125main/BE3
CRANK: Mazzucchelli cut and balanced short stroke
GEARING: Standard
TOP SPEED: 120 km/h
CRUISING SPEED: 105 km/h as long as I want...
OIL: Motul 800
GEARBOX ADDITIVE: Lucas
30phbh Dellorto 210 Reedvalve:
Main jet 130-135
Needle x2
Atomiser Av264
Slide 40
pilot 50-60
(Info courtesy of Diablo)
Scooter: PX125/PX150
Engine: Mallossi 166 cylinder. Extra tuning: Transfer bridges in spigot cut out - bottom of exhaust port lowered 1mm - boost port opened up.
Crank Case: Transfers ported and matched to cylinder, inlet port opened 4mm each end and matched to 26mm carb, with airbox matched to suit.
Oil: Autolube discarded, run on 3% pre-mix in tank.
Crank: 'cut back' 14mm (approx 180 degree inlet)
Pipe: Sterling exhaust
Timing: Standard
Clutch: 22 tooth
Carb type: 26mm Spaco with air box and standard filter. Oil hole in carb blanked off.
Main Jet: 130 main
Idle jet: 55/160
Air Corrector: 160 AC
Mixer: BE3
Slide: 04
Scooter: PX125
Engine: T5 casing, AF TS1 barrel, extra boost port, 188/128 port timing, Readspeed centre plug head, Wiseco Yamaha YZ 250 piston,
Yamaha reed block with Boyeson twin stage reeds, Mikuni fuel pump.
Oil: Castrol TTS @ 3% pre-mix in tank.
Crank: Full circle P200, (57 stroke), widened 10mm. Rotax 120mm rod.
Pipe: PM.
Timing: Parmakit set to 15 deg @ 9000 revs.
Clutch: Old style 7 spring 22 tooth.
Carb type: 32 VHSA
Main Jet: 162
Needle: X57, clip on middle groove
Slide: 35
Atomizer: DQ267
Idle: 40
Choke: 60
Float seat: 200
Info provided by Sean Brady:
Scooter: vespa 200 with polini kit (single ring piston)
Head: pm tuning head(30cc approx) (malossi type )
Pipe: pm tuning pipe
Tuning: ported/matched casings , hp4 flywheel, t5 fourth gear, cosa banded 23tooth ,4 plate clutch, ngk b8es plug
Crank: mazz crank
Timing: 15/16 btdc (which does require much filing of slots in stator)
Carb: 28mm carb,run through malossi hose to frame
carb settings..................
dellorto 28mm phbh
slide 40
needle x2, on first or second notch
diffuser/atomiser as 266
pilot 63
main jet 130(until run in )
choke 70
fuel tap 225
(ps - reason for this set up/tune/gearing etc....................rider is 20 stone,takes misses on as well and lives in hilly north yorks etc)
Scoot: PX150
Engine: Malossi Kit 166cc, cases matched and ported, cut original crank 19mm, inlet port opened 5mm rear/2mm front, lightened original flywheel
Carb: 30mm OKO/PWK (125main, 48pilot, JJH needle 3rd clip, 1.75 air screw, ScootRS manifold matched to case
Pipe: ScootRS
Oil: Maxima Super M, 2% pre-mix in tank
Timing: standard 18* BTDC
Gearbox: standard, SIP banded Cosa clutch, slots milled to 22mm, reinforced XL springs
Pipe: JL3
Main Jet: 160 main
Idle jet: 100/50
Mixer: BE4
Pinasco 215 cc
SCOOTER: P200E 1983
HEAD: Pinasco
GEARING: Standard
TOP SPEED: 120 km/h
OIL: Motul 800
Main jet 130-135
Needle x2
Atomiser Av264
Slide 40
pilot 50-60
Timing: Standard
Clutch: 22 tooth
Main Jet: 130 main
Idle jet: 55/160
Mixer: BE3
Slide: 04
Scooter: PX125
Pipe: PM.
Carb type: 32 VHSA
Main Jet: 162
Slide: 35
Atomizer: DQ267
Idle: 40
Choke: 60
Float seat: 200
Crank: mazz crank
dellorto 28mm phbh
slide 40
pilot 63
choke 70
fuel tap 225
Scoot: PX150
Pipe: ScootRS
- registered user
- Contact:
Malossi 221 cc
SCOOTER: 150s spanish
ENGINE: malossi 210 rework ( barrel and piston )
HEAD: sck for 210 with longstroke
PIPE: taffspeed
CARB: SI24/24
main jet 140
CRANK: Mazzucchelli cut and balanced long stroke
GEARING: Standard + 4th T5
TOP SPEED: 130/140 km/h
CRUISING SPEED: 110/120 km/h
OIL: castrol
IGNITION : 17°
HP4
PIPE: taffspeed
CARB: SI24/24
main jet 140
OIL: castrol
IGNITION : 17°
HP4
- registered user
- Contact:
polini 208 2 piston rings
SCOOTER: 125 gtr
ENGINE: polini 208 new version
HEAD: sck for polini 208
PIPE: taffspeed
CARB: SI24/24 T5
main jet 140
CRANK: Mazzucchelli cut and balanced long stroke 60 mm
GEARING: Standard
TOP SPEED: 130 km/h
OIL: castrol
IGNITION : 17°
original flywheel
SCOOTER: 125 gtr
PIPE: taffspeed
CARB: SI24/24 T5
main jet 140
GEARING: Standard
TOP SPEED: 130 km/h
OIL: castrol
IGNITION : 17°
original flywheel
Px 200 arcobaleno with 125 motor..
Seigiorni Quattrini M1X
RMS crank tuned for 63-132 inlet port
22/65 and 36 teeth fourth gear
original ignition and elven research delayer linear retarder
SIP original left hand exhaust
30 phbh delly
malossi elbow for frame
Max 135 Min 55 slide 50 AV260 atomizer Needle x2
Why 125 motor for 200 vespa?
Vibration-free motor, and same power to my malossi 210 in identical configuration.
Also, identical fuel consuption...
30 phbh delly
- sean brady scooters
- Dealer
- Contact:
think you mean 40 slide..
- registered user
- Main scooter: px 225 ish
- Contact:
i am building a vespa225 with a 28 bhph delorto do`s any one have any set up guides for this configuration also running a R/H JL PIPE
- registered user
- Main scooter: Vespa PTS1E
- Contact:
Scooter: PX125
Engine: T5 casing, AF TS1 barrel, extra boost port, 188/128 port timing, Readspeed centre plug head, Wossner Yamaha YZ 250 piston,
V-Force reed block.
Mikuni fuel pump.
Pipe: PM.
Timing: Parmakit set to 12 deg @ 9000 revs.
Clutch: Old style 7 spring 21 tooth.
Carb type: Mikuni TM30 with CamLam PJ
Main Jet: 200
Needle: 5EL68
Slide: 45
Pilot: 30
Float seat: 3.5
V-Force reed block.
Mikuni fuel pump.
Pipe: PM.
Main Jet: 200
Needle: 5EL68
Slide: 45
Pilot: 30
Float seat: 3.5
hi can anyone give me timming and rough jetting for 172 mallossi runing standard carb no porting etc and no autolube exhaust will be pm going to strop and do bearings and seals
