PX200 Gearbox woes
Hotspur
Main scooter: Lambretta LI175
Had a pal and his PX200 round today, as getting first gear is all but impossible. Changed both gear cables, and adjusted. Took off the selector box and tightened a loose rod. Adjusted the clutch, started it and everything was fine. Took it for a run round the block, and it drove lovely. Then after five or ten minutes, back to square one. Gears VERY difficult to get, then it stuck in second, and now can't get first again. One thing I did notice, is that it does rattle a bit when the clutch is pulled in. Any suggestions if there's something we missed, or what to try next would be most welcome.
Thanks
Pete
    Users browsing this forum: Semrush [Bot] and 28 guests
