Woodruff Key
Bilko
Main scooter: LI150
Finally got back to working on the 250 after a break.
Took the flywheel off and the woodruff key had sheared
Should I be worried about this happening after only about a dozen kicks and about five minutes of the engine running?
I did notice that there wasn't a lot sticking out of the key in the crank before it, but didn't think it would have been a problem.
Bilko's Oily Blog
Triken
Main scooter: 200cc Trike
In my experience, a sheared woodruff key was caused by the flywheel not being tightened up correctly (slack rather than overtight) and it didn't take much to shear it!! I am not saying that is what caused yours, just that it's what caused mine.
have you lapped the fly wheel to shaft ?....there my be a high spot on the taper allowing movement
Bilko
Main scooter: LI150
Triken wrote:In my experience, a sheared woodruff key was caused by the flywheel not being tightened up correctly (slack rather than overtight) and it didn't take much to shear it!! I am not saying that is what caused yours, just that it's what caused mine.
This was it. I didn't originally have the flywheel tightened.
Thank you
Bilko's Oily Blog
paulmgreen
Sorted then!
www.JPPLambretta.co.uk
Bilko
Main scooter: LI150
Yes! I hope!
Bilko's Oily Blog
This happened to me Bilko on my Series 2 , Strobed the timing , left it overnight came back next day and had forgot to fully tighten the flywheel :oops: :oops: :oops:
Bilko
Main scooter: LI150
Toddy wrote:This happened to me Bilko on my Series 2 , Strobed the timing , left it overnight came back next day and had forgot to fully tighten the flywheel :oops: :oops: :oops:
Glad I'm not the only one to forget
Bilko's Oily Blog
At my age I have to check everything twice or I will forget lol
jonny snatchsniffer
its a bit like forgetting to put your nob away after having a p155
