Slipping Clutch?
jimmo
Main scooter: Lambretta GP TS1 230 JB
Had a blast on my Ts1 today - when the engine is warmed up the clutch seems to slip more so in 4th gear.
I only replaced the plates last year and dont do massive miles.
I have a 4 plate clutch with px springs within the standard springs.
The motor was dyno'd at 21hp with 16 lb torque - am I asking to much from the 4 plate clutch?
Is it time to replace with a 5/6 plate?
thoughts please :?: :?:
bazman
I've similar hp to yours think it's 18ftlb tourque though , and had same issue , after 400/500 miles clutch started slipping . Was standard 4 plate with MB springs. Now use their 5/6 plate version and have done 2000 odd miles no issue.
If you think about it the standard output of say a GP200 is 11hp and you're nearly doubling it!! So yes go for 5 plate at least, JB Tuning do a good 5 plate kit, few of my mates use them.
soosh
I switched to Readspeed springs and can still get away with a 4 plate on my TS1 if that helps.
As Baz said i had a four plate but with center spring not to bad but slipped a bit when giving it some and suffered from a heavy lever , changed to JB 5 plate spot on clutch and easier lever as well .
