phbh 28 mm -- has oil feed pipe -- do i blank it off
boxofbits
ive just built an engine and the carb iam using seems to have brass pipe on the choke side -- is this an oil feed pipe and do i need to blanck it off - or will it not make any diffrance--
let me know -- and how do you blank it off if i need to do it?
definitely blank it off
little rubber caps available for this very purpose
I fill the end of the tube with solder, and then silicone this cap on.
ove
As byron said i`ve blocked mine off with solder,job done for me.
boxofbits
without it blocked would this weaken the mixture as air could get in?
boxofbits wrote:without it blocked would this weaken the mixture as air could get in?
yes, probably quite catastrophically...
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 9 guests
