Page 1 of 2
17/47
Posted: Sun Jan 30, 2011 7:41 pm
by Eibar
Is there a chain available for this set up that doesn;t have the word "stretched" in its name
Re: 17/47
Posted: Sun Jan 30, 2011 7:48 pm
by LI150
Could you use a longer chain and one of the chain guides that pulls the chain down to tension it ?????
Re: 17/47
Posted: Sun Jan 30, 2011 8:24 pm
by RICSPEED
there is a new one out that can be fitted either way ....push up and pull down
Re: 17/47
Posted: Sun Jan 30, 2011 8:37 pm
by soulsurfer
Jocky's one, available from SIP, assuming it's actually in stock.
Re: 17/47
Posted: Sun Jan 30, 2011 8:40 pm
by Eibar
cheers
Re: 17/47
Posted: Mon Jan 31, 2011 6:08 pm
by Eibar
Re: 17/47
Posted: Mon Jan 31, 2011 6:47 pm
by paulmgreen
Its shown there on sprockets of the same size......... somehow i think it would react differently in a Lambretta setup???
Re: 17/47
Posted: Mon Jan 31, 2011 7:02 pm
by RICSPEED
paulmgreen wrote:Its shown there on sprockets of the same size......... somehow i think it would react differently in a Lambretta setup???
i think i know what you mean Paul - the chain at the top must by any law of physics that you care to throw at it be at the same speed as the lower chain no matter what the sprocket combo is,but not being parallel it wouldn't stay put
Re: 17/47
Posted: Mon Jan 31, 2011 7:42 pm
by Eibar
Good point , I can't seem to find alternative chain tensioner system to enable a 17/47 setup to be used.
Re: 17/47
Posted: Mon Jan 31, 2011 7:45 pm
by RICSPEED
Eibar wrote:Good point , I can't seem to find alternative chain tensioner system to enable a 17/47 setup to be used.
corrado does the push up type ,these should allow any combo with just one chain
