17/47
Eibar
Main scooter: Eibar TS1 1966
Is there a chain available for this set up that doesn;t have the word "stretched" in its name
potato
LI150
Main scooter: Series 2 LI150
Could you use a longer chain and one of the chain guides that pulls the chain down to tension it ?????
there is a new one out that can be fitted either way ....push up and pull down
Jocky's one, available from SIP, assuming it's actually in stock.
Eibar
cheers
potato
Eibar
potato
paulmgreen
Its shown there on sprockets of the same size......... somehow i think it would react differently in a Lambretta setup???
www.JPPLambretta.co.uk
paulmgreen wrote:Its shown there on sprockets of the same size......... somehow i think it would react differently in a Lambretta setup???
i think i know what you mean Paul - the chain at the top must by any law of physics that you care to throw at it be at the same speed as the lower chain no matter what the sprocket combo is,but not being parallel it wouldn't stay put
Eibar
Good point , I can't seem to find alternative chain tensioner system to enable a 17/47 setup to be used.
potato
Eibar wrote:Good point , I can't seem to find alternative chain tensioner system to enable a 17/47 setup to be used.
corrado does the push up type ,these should allow any combo with just one chain
    Users browsing this forum: Semrush [Bot] and 8 guests
