which piston to order
psychedelicropcircle
running a mer eur crank 58mm do i order imola piston 107mm rod or 116mm rod?
CPH Lambretta
Main scooter: DL 150 1970
That depends if your crank has a 107mm rod or a 116mm rod. Mecur sell both.
The 107 is more normal. What were you running before?
Slow is the new fast!
