malossi 210 pinging problem
Posted: Sun Jan 23, 2011 4:51 am
hi all!,
im having problems seting up my malossi 210 ive tried a larger main jets, retarding the timing and a lower compression head i tried adding octane booster of 7 points and i cant stop the pinging any ideas ?????
malossi 210
mmw 10:8 to head
maz full circle 60mm crank
1.5mm base packer on the bottom of the barrel
mmw evo 2 reed block with bgm rd 350 style reed
vintage 226 hotwing pipe
pk 1800gram flywheel
bgm 30mm pwk carb jetting 145 main jjf needle 48 pilot
mukini rectangle vacum fuel pump
currently the main is a little big i think
malossi 210
mmw 10:8 to head
